I’m trying to find a replacement mains power on/off switch which is located within the front door DREEFS control panel.
The mains power switch is a ‘T’ shaped item with the spade contacts at the bottom end. The casing says wi39/01. I cannot find the switch anywhere.
The DREEFS control unit has the following markings:
07-0130.3006
D.03.12.01 282
UB-P5-Z0-A2
Re: Whirlpool ADG 957 – Dishwasher Replacement Power Switch
Yes it is a part within the main control panel, the ‘T’ shaped mains toggle switch sits in a moulded area of the housing. It can easily be removed once the two spade connectors are removed. I’am sure the mains switch is at fault as a power tester shows the supply is adequate to the switch, but not beyond. I don’t want to spend +£50.00 on a new control panel when hopefully i can source the replacement toggle switch. I’m trying to find a more detailed drawing of the DREEFS control panel with no success.
The only item i have come across is the following PDF for parts of the dishwasher: http://bauknecht.dw-gmbh.net/zeichnungen/gsx4756.pdf
It is not the door microswitch, The item is within 6200. Thanks for your help
Then I’m sorry that we cannot help you other than supplying you with a complete unit. Individual components on a board like this are not generally available to us in the trade. Besides time costs money and messing around with components is not something we would even attempt let alone be bothered trying when sticking a new board in will sort. (if you catch my drift?) 😉
