Whirlpool ADG2900 (854276201710) Element
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Whirlpool ADG2900 (854276201710) Element
  • #73546
    Hollytree_Technical
    Hi All
    I need to replace the element in the above machine as the thermal fuse has blown, SIOS gives me a part number of 481225928843 which no one has in stock, as this is a Fisher and Paykel machine re-baged (I think – going by all the F & P labels inside) would 5045175117264 (connect part no) be the same part? It looks very much the same from the images but I would like some confirmation if possible please.
    Thank you
    Jem
    #387890
    johnmac11
    Re: Whirlpool ADG2900 (854276201710) Element
    I can’t tell by the Whirlpool numbers but there are only two different heaters for the F&P dishdrawers. 528616 fits all the variants of the DD603 and 522090 fit all the DD605 versions. IIRC the rating plate should show the original F&P model number. I would bet on it being the earlier 528616 part.
    John
    #387891
    Hollytree_Technical
    Thank you John
    It does look like the same part so i will go with it and hope that it is especially as it is half (or less) the price of the whirlpool one and not special order.
    Jem
    #387892
    johnmac11
    The two heater plates look very similar but the connections are different. If I was a gambling man I would go for 528616.
    John
