Guys
Re: Whirlpool ADG332 (rating plate no: 8542 332 15510)
Re-posting this message, as I didn’t a get a reply to the original …
Original Problem: The machine didn’t respond to any control inputs at all. No lights/LEDs illuminate when the programme selector is turned from OFF to one of the three programme modes or when the POWER pushbutton is pressed.
I fitted a new Main Control PCB (481221478477) which you kindly supplied. This has improved the situation, but machine still has a problem …
Current Problem: Programme selector LEDs now illuminate when the programme selector is turned from OFF to one of the three programme modes. When the POWER pushbutton is pressed, the programme initiates (POWER LED illuminates and drain pump runs for ~20 secs) then the POWER LED flashes an error code(?) 6 flashes repeated.
I’d really appreciate any further advice you can offer?
Thanks again
