whirlpool ADG332 S WH
  • #83538
    lilbobspad
    Please can someone tell me why the dishwasher is pumping and flashing green constantly when I switch on to any program and how I can reset it? Thanks
    #423031
    Re: whirlpool ADG332 S WH
    if the pump is not stoppingf then most likely the anti flood device has activted
    there is a float in the base of the dishwasher this fault is most likely due to a leak flooding the base. remove this water and if there is no leak machine will work again. if there is a leak then fault will re-occur
    lilbobspad
    Thank you Dave. What does the float look like? Just moved in the house and dishwasher was already installed.
    Carole
    #423033
    remove kitchen kick board
    remove lower cover of dishwasher
    if you find water in this area mop it out and try unit
    remove plug before removing base
    after water moped out try dishwasher with base open. look with a torch for leaks. if it stays dry turn off box it up and use it
    float by ther way is a polystyrene disk in the base that operates a switch if water is present
