Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › whirlpool adg450
- This topic has 13 replies, 10 voices, and was last updated 17 years, 7 months ago by
msappliance.
September 2, 2008 at 4:37 pm #39176
msappliance
Participantcan any one tell me y the above dish washer when set on any cycle drains as normal then when it is supposed to fill it drains and fills at the same time for about 2 seconds. there is then about a 3 second pause and repeats its self again then again etc. when i open the door to check for a fault code the programme it was set on keeps flashing with no pause.
Thankyou.September 3, 2008 at 8:37 am #261543DentedPorsche
ParticipantRe: whirlpool adg450
Hiya,
If you send me your email address I’ll send you the info on this one.Brian
May 31, 2009 at 9:52 pm #261544stratfordgirl
Can anyone help with this strange fault, which I have come across again on this d/w model (Whirlpool ADG450-3, a slimline made by Smeg). No fault code is displayed. There’s no obvious fault with the solonoids, etc and the PCB resets OK. Am I right to suspect the PCB, or have I missed another possible cause?
June 1, 2009 at 9:49 am #261545msappliance
have you tried taking out the filters and cleaning the black mesh on the right side? i have found these to blocked and gungy.
June 1, 2009 at 10:17 am #261546Simon46
one flash perhaps= NTC
S.
June 1, 2009 at 7:19 pm #261547stratfordgirl
Thanks both for your suggestions. There’s no black mesh under the filter on this one though, as its a rebadged late Smeg, not a Whirlpool type. Also its definiteley not showing a fault code – the programme light flashes to show whichever programme is running. Any other ideas would be welcome as its a rare and expensive PCB.
June 1, 2009 at 7:31 pm #261548PGS
Try the harness at bottom of door, you will find at least one broken wire.
June 1, 2009 at 8:56 pm #261549clivejameson
Have you checked for earth faults?…they play havoc with the pcb…the usual suspects are the suppressor and terminal block, occasionally the element 😉
June 19, 2009 at 8:23 pm #261550stratfordgirl
Thanks all for your input. Just for the record, in this instance the fault was cured by fitting a new control module.
July 14, 2009 at 9:06 pm #261551cornwell40
Is there a fault code list for this dishwasher?
Every time I start the programme it does something different so I would like to be well armed before I go back.TC
July 14, 2009 at 9:17 pm #261552Penguin45
Something in your inbox.
July 14, 2009 at 9:54 pm #261553cornwell40
A Gent and no mistake, guvnor ( Dick Van Dyke stylee accent) 😉
Cheers Chris
TC
July 15, 2009 at 9:39 pm #261554brians2
am reading with interest this thread i have a 450-3 which is also filling ok twice on a programme but after filling and heating third time it appears to start to overfill filling base?? (type 851116115000) have checked all listed faults and any advise greatly appriciated
September 14, 2011 at 4:13 pm #261555DOCTORDOOM
hi. can anyone confirm that the original fault posted in this thread was cured with a new pcb? I’ve got the exact same fault on one of these. Thanks
