Whirlpool ADG6340AV hose
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Whirlpool ADG6340AV hose
  • #32020
    Seamy
    ADG6340AV 854233215720. Hose from circulation pump needed & clips.
    Can’t see it on Sios but outlet from circulation pump is showed “d” but can’t seem to find hose that goes on there.
    thanks in advance
    #233285
    senseib
    Re: Whirlpool ADG6340AV hose
    If you mean the short hose that is moulded onto the spray pump casing, i don’t think it is available. Suggest you sort through any small hoses you have and try and make do, because I think the intention is to make you buy a complete new unit. 😈
    Brian
    #233286
    Seamy
    Don’t think it was moulded on, this is a ribbed hose & was held on with a clip from memory.
    On circulation motor, water enters via heater & is expelled out top spout of wash-pump.
    The hose i need connects to this top outlet from circulation motor & seems to have been nibbled by a mouse as it is spraying water out in several places.
    #233287
    senseib
    Not counting the big one in the middle where the heater connects, how many other outlets are there on the spray pump?
    Is it like this – http://www.4whirlpool.co.uk/cgi-bin/pic.pl?pid=954230 Or is there another outlet as well?
    Brian
    #233288
    Seamy
    Bit like that only pipe comes out at top.
    Theres one other outlet onto which a ribbed (concertina type) hose is fixed with a clip i thought.
    Doesn’t look like that motor type though.
