whirlpool adg642
  • #44638
    suedehead1
    hi its a whirlpool dishwasher adg642/1 1x
    8542 769 15889.
    when you switsh it on the pump goes for 2 seconds and the start light goes on, then the pump stops for a couple of seconds and the start light goes off. it repeats this forever.
    there are no flashing lights i checked the pressure switch, heater, motor, and ntc, there is no water in the base of the dishwasher,
    i think it is the pcb any ideas welcome and part number for pcb would also be appreciated thanks.
    #281748
    Re: whirlpool adg642
    Constant flashing is F1 – NTC failure.
    suedehead1
    fitted a new ntc id didnt fix it i have also wired up another motor,pump pressure switch but it still flashes the light and the pump pulses which i also changed any ideas?
    #281750
    Specialist01269
    Have you checked the wiring from the NTC to the PCB? If the wiring is open you get this also check the drive Triacs.
    #281751
    suedehead1
    i have checked the wiring and visibly checked the pcb i suspect a relay has suck on it.
