Whirlpool ADG642/1WH semi – integrated dishwasher. 8542 769 15850. Serial no:- 330450 004575.
Switch on, select Rinse/Hold cycle. machine starts, then proceeds to wash, then heat……. 😕 On all the other settings, 30min, 50deg and 70deg the machine is dead. I also can’t get it into test mode.
I’ve had the PCB out and there are signs of discolouration around some resistors in the middle, but nothing drastic.
I can’t think what else could cause the PCB to behave like this apart from it being faulty. The machine fills, drains, heats, and the wash motor works fine.
Anyone have any thoughts on this?
Steve.
