Whirlpool ADG644 Fault
  • #52778
    myfil
    Went to a Whirlpool ADG644 integrated dishwasher (8511 644 15872)
    Put it on any pgm and it (1) pumps out for a spell (normal) (2) fills a bit (not to level) (3) stops and gives groups of 7 flashes
    The odd thing is when I first tested it, it was only giving six flashes.
    It has that nasty Askol washpump but it ain’t that because no voltage is getting to the Asholl (per meter test), so it is not the failure of the Askol to start up (I know these pumps fall to bits, but this machine looks fairly new)
    All looks very clean in the base pan. (Got a small grill visible on the right side of the inside bowl (sump). Attached to a removable device. Turbidity sensor?)
    Any wisdom and guidance appreciated.
    Regards to all
    Myfil
    #313097
    martinm
    Re: Whirlpool ADG644 Fault
    F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
    as long as theres water coming in then itll be the flowmeter situated on air break left hand side
    AIR BREAK.
    #313098
    myfil
    Thanks Martin
    I’m very familiar with cleaning out the Bosch equivalent of this, also old Zanussis etc. Is this a blockage problem from buildup of muck, or will I need a new part? Give me your best guess.
    (I trust the left side panel comes off, as with Bosch/Neff??)
    Cheers
    Myfil
