Whirlpool ADG69161X (851169115730) D/W
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADG69161X (851169115730) D/W
  • #84494
    rocker
    This D/W is showing F6 fault code.- before removing from units, I started program, no water went in and code F6 came up, pulled the machine from housing restarted this time machine filled with water cycle started runs for 5 /6 minutes then it aborts water pumps out and F6 shows again. I have tested heater for circuit & earth leak.
    There is a unit in the sump area that looks like a optical reader !! not sue how to test this !! also no sure if this is the fault. any advice would be welcome. john
    #425771
    Grendal
    Re: Whirlpool ADG69161X (851169115730) D/W
    f6 is usually the water matrix on the left hand side pt no is 481241868368 However it is worth giving the switch in the sump a good clean first and also check for broken wires in the door
