whirlpool adg722 dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool adg722 dishwasher
  • #17068
    brian2909
    help!!! we have a whirlpool adg722 dishwasher which when you turn it on the light flashes 10 times then stops then flashes 10 times please help me before the wife makes me do the dishes again.
    #172865
    Dave_Conway
    Re: whirlpool adg722 dishwasher
    Whirlpool fault codes only go up to F9 (9 flashes), if it’s definitely 10 then there may be either a software error on the PCB or another component failure is causing “confusion”.
    Engineer time to be honest as these are complex appliances, check the repairs@ link below 🙂
    #172866
    DentedPorsche
    10 flashes = Optical water indicator failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
    Had a quick look at the diagram for your machine and couldn’t see an OWI fitted so would suspect a module problem.
    As these are expensive it’s probably best you get an engineer in to check it out further.
    Click on the repairs@ link to find one near you.
    DP
