Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool ADG7340 D/W 854234015810
- This topic has 7 replies, 4 voices, and was last updated 19 years, 9 months ago by
mike412.
June 19, 2006 at 5:49 pm #18577
mike412
ParticipantHi Guys.
I went to this dishwasher on friday, flashing F4, draining failure. Found a piece of plastic in the drain outlet and thought this was the problem. Also found the black grill on the r/h side of the sump choked up with tissue(?).
Dishwasher now drains ok, but will not stop draining. Seems as if it does not want to advance on to the next (fill) part of the prog. I looked for some sort of pressure switch arrangement but could not find. As usual its a built in job and not an easy removal, Will be grateful if someone can point me in the right direction.Any assistance greatly appreciated.Thanks in anticipation,
Mike.June 19, 2006 at 6:12 pm #179510bobokines
ParticipantRe: Whirlpool ADG7340 D/W 854234015810
Mike, the black grill that you mention is the pressure switch. It is a rubber membrane with a microswitch behind.
I have seen several leaking where a customer has prodded the holes with a screwdriver. 😯
The whole unit comes out quite easily from underneath. I believe it is on a twist bayonet. You can get access from the front.
Bob
June 19, 2006 at 6:39 pm #179511gegsy
Hi Mike
Switch Diaphragm/Water Indicator if needed – p/no – 481227128407Greg
June 19, 2006 at 8:29 pm #179512mike412
Many Thanks for your replies.
I think that its more than likely that I have pierced the diaphragm with my mk 1 poker and prodder. I have ordered a new one and expect a result.
Cheers,
MikeJune 19, 2006 at 8:56 pm #179513gegsy
mike412 wrote: I have ordered a new one and expect a result.
Lets hope its better than Englands tomorrow 😀
June 19, 2006 at 9:42 pm #179514roly16
What’s England doing tomorrow? 😯
June 19, 2006 at 9:45 pm #179515gegsy
Hi Geoff
Losing probably, I take it you another avid world cup follower 😆Greg
June 19, 2006 at 9:51 pm #179516roly16
Hi Greg
I do my best to be working when the football’s on so
a] the roads are quiet and
b] I don’t have to listen/watch/think about it!. 👿
geoff -
