Can anybody help been at this today the programe starts fills okay then when circulation pump should kick in it just sits, then after a couple of minutes it drains and then bleeps 4 times no flashing lights cheers JJ
cant see a picture of the motor but as lot of later motors are just sized up drain pumps
so
run the unit with the side off so you can access the motor. since the field coil of the motor is an electro magnet to see if its active touch the field laminations with a large screwdriver. if its active and not moving its gone
