whirlpool adg7460 stops after 4 mins
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool adg7460 stops after 4 mins
  • #65295
    e17
    I have a two year old integrated dishwasher which stops a few mins on all cycles with water left in the machine. Checked i/p and output pipes are ok. Cant see lights as integrated but beeps as if finished.
    The water softer Bitron has a cylinder full of crystal gunk I think this is normal as cant see any way of getting it out?
    I see a thread about faulty NCT is that likely
    thanks
    #359990
    nigegt
    Re: whirlpool adg7460 stops after 4 mins
    When it beeps and finishes, open the door and look at the start switch light. This will flash a set number of times then a one second gap and so on. Count the flashes and this will give the fault code and post what you find. 3 flashes is heater fault for example.
    Nige
