Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool ADG7470/1 (854274715001) Dishwasher Visual/Blink Code
- This topic has 5 replies, 2 voices, and was last updated 9 months, 3 weeks ago by
jontymox.
June 13, 2025 at 4:12 pm #103415
jontymox
ParticipantGood afternoon all,
I’ve had a look at the above integrated dishwasher, and would appreciate any assistance with the fault/s.
Essentially, when a programme is set, the machine drains more than usual. i.e. drains, pauses, drains, pauses, seven or eight times. (for approx’ three minutes)
There is no attempt to draw water, and I noticed that the Off/Cancel button flashes eight times, pauses, flashes eight times…
However, I don’t know what the above relates to, and my recent online search suggests a ‘water level fault.’ (Whirlpool/generic on UKWhitegoods site)
As I’m recovering from knee surgery, and unfamiliar with the above any help would be appreciated. (I did remove and refit the dishwasher on site, but didn’t find anything of note, and also tried resetting the appliance to no avail.)
Thank you,jonty
June 13, 2025 at 4:29 pm #493073electrofix
Moderatorthese machine are very prone to broken wires at the bottom of the door
but be careful as there are often multiple wires of the same colour
June 13, 2025 at 4:35 pm #493074jontymox
ParticipantThanks Dave,
That is very helpful, as always!
I’ll return early next week, and inspect further.
jontyJune 24, 2025 at 9:06 am #493075jontymox
ParticipantSorry for the late update.
Having returned to have another look at the above dishwasher, the complete wiring harness is good, as far as I can possibly determine.
May have to admit defeat on this obscure fault.
jontyJune 24, 2025 at 9:35 am #493076electrofix
Moderatorwell as far as i can see its not got a pressure switch (cant be certain as no official part breakdowns)
if its using virtual sensor technology then a worn drain pump will give this fault. the theory is that a pump that’s pumping water draws more current and so does a worn pump. so board thinks its still full
suggest you pull the drain pump and see if its stiff or has lots of shaft play
June 25, 2025 at 4:54 pm #493077jontymox
ParticipantYes, I agree Dave,
I couldn’t locate a pressure switch.
Not sure if I’ll have chance to confirm, and test further as the dishwasher is in rented accommodation, and the landlord is being slow in responding. (I sense they may be replacing the dishwasher.)
I’ll update if possible.
Thanks again,
jonty
