Whirlpool ADG7470/2 854274815000
Home Forums Trade Technical & Spare Parts Forums Whirlpool ADG7470/2 854274815000
  • #99103
    chuffy
    This built in dishwasher starts a programme as normal :- pumps out for a short period then fills for about a minute or so then goes very quiet and remains so.
    When the door is opened at this point only the start/resume light is flashing continuously which is normal on this appliance when a programme is interrupted.
    No other lights are flashing.
    I’ve checked and tested the circulation pump/ wiring etc.
    I suspect flow meter or possibly control module.
    Has anyone had a similar problem?
    Cheers.
    #474995
    assume you have checked circulation pump is energised as had a few where these dont start when powerd up
    dave
    #474996
    chuffy
    Hi Dave,
    Obviously difficult to test when full of water but I’ve had m/c out and connected mains supply direct to the circulation pump and it pores up fine.
    #474997
    chuffy
    Powers up fine!
    #474998
    have you checked wiring harness at the bottom of the door ?
    chuffy
    Not yet was going to check that on my next visit.
    Trouble with built in dishwashers you can spend so much time removing from housing, then dismantling to diagnose the fault and if you don’t find the problem the customer is reluctant to pay for your time.
    Sometimes you just wished you had walked away!
