Whirlpool ADG7540/1 integrated dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADG7540/1 integrated dishwasher
  • #54962
    jontymox
    Good afternoon,
    Has anyone had a fault with the above machine not accepting programmes?
    Having selected any of the 3 programmes, the machine immediately beeps continually, and the prewash light comes on. (regardless of programme)
    I have had the m/c out to try and ascertain anything obvious, but suspect the control module in the door.
    Is there any way of independant engineers testing these units, without substitution to confirm fault?
    I’ve tried a couple of specialists who cannot help with these control units, as the chips are unavailable.
    Naturally, I don’t want to order a £100 plus item if not faulty!
    Kind regards,
    jontymox
    #321506
    Re: Whirlpool ADG7540/1 integrated dishwasher
    From page one of error codes thread:-
    Whirlpool Dishwasher Error codes.
    F0. 10 flashes. Sensor Break (Only shown in test programme. Not visible to customer).
    F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
    F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
    F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
    F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
    F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
    F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
    Water Valve Closed. Water inlet hose blocked.
    Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
    F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
    F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
    F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
    FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
    FB. 12 Flashes. Motorised Diverter Valve
    FC. 13 Flashes. Water Hardness Sensor Failure
    A fault with no fault code indication = faulty module
    These codes should cover the entire range of Whirlpool dishwashers.
    Test Mode
    Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
    Open the door and set the program to the first program. (Normally rinse).
    Turn the power off.
    Press and hold the start button and while holding turn the power on.
    After a little while the start button will flash, release the button.
    Press the start button once and close the dishwasher door.
    The machine will now run through a diagnostic routine.
    If memory serves me right it takes about 20 mins.
    The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
    To exit diagnostics at any time just press and hold the start button till the programme is cancelled.
    (Author: Dented Porsche)
    Mike.
