Re: Whirlpool ADG7540 Dishwasher
Kevin is right, the flowmeter (water wheel) sends pulses to the module, if it doesn’t get enough pulses it aborts the fill. At the same time the pressure switch operates and sends a signal to the module when a set amount of water has entered the cavity. If it takes too long to operate the pressure switch it again aborts.
Check the connector to the flowmeter, pull it off, tighten it and plug it back on is all it normally needs. Make sure the pressure switch isn’t gunged up.
I’ve also had this problem where the water flow has been too low, make sure there is good pressure and flow at the end of the hose.
Hope this helps.
Brian
