Whirlpool ADG7540 Dishwasher Not Heating?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADG7540 Dishwasher Not Heating?
  • #29560
    laurenceuk
    I am going to this appliance Wed. The complaint is not heating but it goes
    through the prog to the end.
    Is there a common complaint on this m/c re not heating.
    Does the heating cct include the `probe feeler` as described in Connect
    Pt number 5031682990711
    I seem to remember fitting one of these a long time ago but can`t remember
    the fault.
    Laurence
    #223607
    gegsy
    Re: Whirlpool ADG7540 Dishwasher Not Heating?
    Sometime you don’t get the continuous flashes for NTC fault, you may find it just won’t heat 😕 even though NTC/feeler may read ok 😯
    laurenceuk
    Hi Gegsy,
    Thanks for your response.
    That sounds exactly what is happening here.
    I asked the customer to put the m/c through a prog again and watch for
    lights flashing but it ended with no fault indications showing and it had
    not heated
    What is the normal NTC reading – if you have it.
    Thanks again
    Laurence
    #223609
    DentedPorsche
    NTC can cause this on the rare occassion.
    Most times, it’s the pcb at fault. Either burnt or scrambled software.
    Brian
    #223610
    spanner51
    I had exactly the same complaint on the same model. heater OK. NTC OK. Connections list 2 modules. One goes at the top behind the facia ( which is what I quoted for, but didn’t get the go ahead). The other one I wasn’t sure about.
    #223611
    gegsy
    NTC
    20 °C 58.1 kOhms
    25 °C 47.1 kOhms
    30 °C 38.2 kOhms
    40 °C 25.4 kOhms
    50 °C 17.2 kOhms
    60 °C 11.8 kOhms
    70 °C 8.3 kOhms
    80 °C 6 kOhms
    85 °C 4 kOhms
    laurenceuk
    Thanks all,
    Thats a great help – gives me the direction to look towards.
    Laurence
    #223613
    laurenceuk
    From the table you kindly posted Gegsy I would hopefully feel confident
    that it is the NTC that is the culprit.
    The customers NTC reading is 4.6K ohms at ambient temp. From the
    table, the PCB is assuming that it is already at temperature hence the reason
    it completes the program normally without heating.
    Thanks again
    Laurence
    #223614
    gegsy
    Jobs a gudden then Lawrence 😉 😀
