Hi Guys
This dishwasher is doing my head in. It stops at the first drain and flashes 4 times indicating drain failure I have changed pressure switch and you can hear the switch click on draining. It also does it in auto test.
Can you help?
check gauze sump filter for greasy film on it or check for proper air gap on outlet hose connection to trap/sink. Also i have seen a low insulation reading on wash pump cause this before
It fills ok, so do you think it could be the flow meter, my experience in the past is when the flow meter is faulty they dont fill properly. I have checked the gauze.
