Whirlpool ADG7550 Service Manual
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG7550 Service Manual
  • #66135
    gmcnicoll
    Does anyone have a copy of the service manual for a whirlpool ADG7550 dishwasher ?
    I have a machine that will not heat the water.
    Cheers
    Grant
    #363196
    Re: Whirlpool ADG7550 Service Manual
    Sorry but here comes the most obvious question: Have you checked the heater?
    #363197
    gmcnicoll
    It’ll be the first thing I’ll check once I get into the thing.
    I don’t have a Torx 15 driver yet. I need to get one.
    Thats why I asked if there was a service manual to see where 1. the heater is.
    2. the temp sensor is
    3. And if there is a thermal fuse.
    I wasn’t sure if these things would be at the bottom? at the back?, and will I need to fully remove the dishwasher as its built in etc.
    Any advice, or a manual would be much appreciated.
    I’ve had trouble on and off with the temp sensor (fault code 1) for a while but it seemed to clear. Now it just doesn’t heat the water.
    Regards
    Grant
    #363198
    gmcnicoll
    Ran the machine last night. Still no hot water.
    It gets a fault code 3.
    Where do I start ?
    Regards
    Grant
    #363199
    gmcnicoll
    It was a broken wire between the control board and the heater.
    The wire was broken near the bottom of the door where it gets flexed all the time.
    Grant
