Re: Whirlpool ADG7560
The fact that it worked on one occasion after the strip down bodes well…it almost certainly is a poor connection to the flow meter which is a well known problem with these. You need to recheck the connection to it, make sure there is no oxidation on the tiny pcb on the flow meter (if there is it can be removed with a pencil eraser or gently with very fine emery), then make sure the harness contacts are squeezed tight and pushed fully on.
If still no luck then a new flow meter it will be (the whole side chamber required)
Don’t forget, unplug before doing anything :zap:
