whirlpool adg7560/1
  • #78210
    monkey
    machine fills, circ pump kicks in,runs for 30 sec,stops for5 sec, runs for another 30 sec, does this continually for 5 minutes,then drains and bleeps 4 times indicating prog has finished no error codes. does this on all progs.. any ideas
    #404838
    Criscold
    Re: whirlpool adg7560/1
    Indicates Pump Problem PM your email if you req further info/Test procedure
    Colin
    #404839
    monkey
    I have changed both pumps and pcb,I am doing the repair through repaircare, I did notice on some previous posts engineers have had the same promblem but I can see that they have had reply to the posts.
    #404840
    Just searching thru posts one guy said it was due to water in the base. So perhaps the anti flood switch is at fault maybe?
    #404841
    monkey
    I dont recall seeing a flood protection switch there was no water there when I took the bottom off,this is the one with the 2 antitamper screws at the front and 2 slots at the back.
