Just replaced the heater on this machine but I believe that you have to run a service test cycle before the heater will work again.
Can anyone please tell me how I go about running the above test cycle. Thanks in advance.
Heater was definitely faulty as it had a burn up. The sheet that comes with the replacement says that pcb has to be reset to restore power to heater otherwise it will not work. Cheers.
turn off machine. press and hold start button and turn on machine. after a few seconds start light will begin to flash, take finger off start button and then just press the start button once more and it will do its test program.
Richardhayes55 wrote:turn off machine. press and hold start button and turn on machine. after a few seconds start light will begin to flash, take finger off start button and then just press the start button once more and it will do its test program.
