Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool ADG7560/1 circulation pump/heater conversion
- This topic has 4 replies, 3 voices, and was last updated 16 years, 9 months ago by
Simon46.
June 24, 2009 at 7:49 am #46594
Simon46
Participant851175715811. Similar to adp8332 but heater is in circulation pump impellor housing 😯 . Is the pump available on its own or does it have to be converted to the new style pump and the flow through heater purchased and fitted where the plastic tube is.? Can somebody look on Sios for me please?
Thanks in advance
S.June 24, 2009 at 8:46 am #290073Simon46
ParticipantRe: Whirlpool ADG7560/1 circulation pump/heater conversion
Just rang Whirlpool. 481236158478. £198.72 😯 . Special order from masterpart.
S.
June 24, 2009 at 2:59 pm #290074Simon46
Can this post be moved to trade technical enquiries please?
I have diagnosed circ pump seized(askoll looking but white bayonet CPO pump) on this UKW job and you can hear PCB trying to start it about 6 times after fill finishes. To try and correctly diagnose the fault i fitted a normal drainpump (bosch) onto circ pump wiring to see if it was definately the circulation pump. when reset drain pump ran all the time but the hoax circulation pump ran all the time on drain as well and not finishing reset.
it ended finishing with 16 flashes when shortwash selected (different coil resistance perhaps?).
Does not flash 16 times if seized circ pump reconnected it just ends the cycle no error codes if shortwash selected.
This is the dishwasher that ends up error 4 if the wash arms are blocked and i cannot see how it checks pressure unless it moniters the circ pump current draw.It is cheaper to replace heater and Circ pump Than buy the circ pump with inbuilt heater but does anybody know if it will work as i have to ask customer for more money for CPO pump and i know it will fail in just over a year again.
Cust is Lab equip technician as well.
http://www.ukwhitegoods.co.uk/modules.p … 1&start=30S.
March 29, 2010 at 4:15 pm #290075timdowning
What was the outcome of this job?
Cheers.
March 29, 2010 at 5:07 pm #290076EFS
I scrapped one of these a couple of weeks ago.
Scandalous spares prices.
I was given part numbers for the motor and heater/pump housing as separate parts but still not worth doing.
I asked someone in the know if I could do a retro with the older parts but was told that it wouldn’t work.
Stitched up by Whirlpool yet again 👿
But at least I got a sale out of it 😉
Steve
