Whirlpool ADG7560/2 dishwasher stops mid-cycle sometimes
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG7560/2 dishwasher stops mid-cycle sometimes
  • #87051
    Adamy
    I have a Whirlpool ADG7560/2 integrated dishwasher which is 3.5 years old but its started to stop at the start of the cycle normally with the first 5-10 minutes.
    However after it stops, I can normally get it to compete a wash cycle on the 2nd or 3rd try.
    I think I managed to generate a fault code by holding down the programme button then pressing start. The led above the start button flashed 5 times then flashed 6 times.
    I shut the do and the dishwasher I assume went in to a diagnostic cycle, when it beeped I opened it and the reset button flashed 5 times follow by a further 6 flashes.
    I’ve cleaned the rotary arm and the dishwasher does work on the rinse cycle so error codes 5. & 6 look red herrings to me.
    Any ideas please?
    #433828
    potty
    Just in case you get to read this, I have exactly the same problem but without the error codes bit. Did you ever solve the problem? Thanks.
    #433829
    this is quite an old unit now and from what you describe it sounds like you may have a problem in the power supply section of the main control board
