I have a Whirlpool ADG 7560/1.
When running, it is making a lot of stuttering noises. I open the door and the water is always being sprayed around.
It sounds like a pump is juddering/stuttering and can’t get going smoothly.
Because the sounds comes from down low, and the water is spraying I am assuming it is the recirculation pump. It drains fine and the cycle ends (although one time it went on and on for ages! but it did end).
This dishwasher is only about 3 years old, but I have had to fix the wiring in the door 3 times! and now this.
The pumps look expensive so I am wondering if I should bother.
I might not bother if these pumps are hard to get at/fiddly to replace.
Any tips/advice?
