Whirlpool ADG937 – 8542 937 15310
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADG937 – 8542 937 15310
  • #26206
    Went to this one today……customer said not doing anything at all….on first inspection programmer appeared to be locked on one program and pressing all buttons made no difference…….so I did reset of start button and things seemed fine…..ran a full test cycle which completed sucessfully
    but when I choose a program say rinse, appliance seems to try to empty for 12 mins or so and then just stops!
    Checked sump in case of leak…but ok……bit mistified why it would
    complete a test though?
    Any ideas welcomed
    cheers col
    #209193
    DentedPorsche
    Re: Whirlpool ADG937 – 8542 937 15310
    Ouch. Not a nice one to get. If you’re not getting any error code coming up then I’d suspect that the pcb software has become a bit scrambled. The test software is sperate to the main software and the test routines may still be ok. If you can get access to a SAM you could try rewriting the software to the pcb. If not it could be an expensive “try and see” with the pcb.
    Brian
    #209194
    Thanks for your reply Brian I suspected it may be something like that so advised customer T suspected PCB module…..as couldnt imagine anything else….its 10 customer years old so they will probably scrap it…..
    Thanks very much for help….Col
