Whirlpool ADG954/2 Type 12137
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG954/2 Type 12137
  • #16259
    gazmo
    Cycle starts,usually left on overnight and emptied in morning. Got up in morning and the cycle had not completed.
    The water was still very hot in the base of the unit.
    Tried to continue but the water just kept boiling.Changed
    cycle and ran rinse cycle. Dishwasher emptied boiling water
    and stopped with cycle end buzzer sounding.
    Cycles will start running but just fill washer with water and
    continue to heat up.
    😕 Any advice?
    #169021
    Dave_Conway
    Re: Whirlpool ADG954/2 Type 12137
    Are you getting any lights flashing on the control panel ?
    This may help by way of a fault code.
    #169022
    gazmo
    The only lights on are the power and the salt regeneration light.
    I have never used salt (soft water area) and the light has always been on.
    I ran the wash cycles with the door open (interlock on) and it seemed to drain first, take in water, heat the water and keep on doing so. I could hear the (presumably) thermocouple kicking inb and the heat element going on & off.
    Most notably the rotating arms had no water coming through them and not spinning.
    Is there a faulty pump that should be forcing the water through the arms?
    #169023
    Dave_Conway
    gazmo wrote:Is there a faulty pump that should be forcing the water through the arms?
    Yes, it sounds like the circulation motor has a problem but at around £150 it is worth getting it double checked by an engineer if you’re unsure. Try the repairs@ link below 🙂
    If you do need a spare, come back and let us know. Power off if you do check yourself please :zap:
