Whirlpool ADG9540 Exit pump on all the time and no water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADG9540 Exit pump on all the time and no water
  • #71046
    neilbennet
    I have a new failure on my Whirlpool ADG9540 DishWasher.
    When a program is selected, with start on or off, the exit pump is running all the time and no water is coming into the DishWasher.
    The Dishwasher has been working normally and then Salt was added, next time wash started the exit pump started and now it runs all the time.
    I have cleaned and checked float valve switch and pressure switch, both ok.
    There is no water in the bottom and there is no water entering the Dishwasher.
    On two occasions the water started coming in after stripping down and refitting, but this stopped after a few seconds.
    The Electronics looks ok and does not look burnt
    Hope someone can help me please as dishwasher is now 15 years old and not ready to be removed.
    cheers
    Neil
    #379889
    Re: Whirlpool ADG9540 Exit pump on all the time and no water
    is it coming up with a fault code
    count flashes on start light
    is float switch in base operating ok ?
    neilbennet
    Float switch is operating ok, checked with a multimeter.
    I have no fault codes, no flashing I press the button and the light comes on and then press and hold and the light goes off. But no flashing.
    Any ideas would be excellent please
    It is the pump running all the time that is confusing me, and not water comes into the unit when I select a program.
    cheers
    Neil
    #379891
    most likely a blown triac in the programmer but you would have to strip timer and test for short circuit
