WHirlpool ADG957 continual beeping
Home Forums Public Support Forums Help And Support Dishwasher Help Forum WHirlpool ADG957 continual beeping
  • #17805
    oldboyracer
    Have one of these, it starts the drain cycle, rinses, starts to pump out (water comes out of drian hose) then start lamp flashes continually and start light flashes continually.
    had the bottom off and checked the pumps are going round and nothing blocking them.
    HELP! the handbook helpfully says Fault: then doesnt tell you anything else. I need saving from buying a new machine!
    Any guidance appreciated!
    #176458
    Re: WHirlpool ADG957 continual beeping
    Any pattern to the flashing light – ie: 1-2-3-pause-repeat?
    oldboyracer
    no sadly, i had read some of the whirlpool stuff in the forum, theres no pattern at all. Just flashes continually and beeps continually until the start button is held down for more than 5 seconds which resets it all.
    #176460
    whitevanman
    hmm thermistor problem?
    #176461
    oldboyracer
    OK, where is that located?
    #176462
    DentedPorsche
    The NTC is on the underside of the bowl, two thin blue wires going to it.
    DP
    #176463
    smee
    did this cure the problem as i have the same fault
    DentedPorsche wrote:The NTC is on the underside of the bowl, two thin blue wires going to it.
    DP
    #176464
    With the power off, check for a reading in Kohms and report back.
