whirlpool adp 4400
  • #80773
    spencer123
    Hi all I have the above machine the problem was,firstly when you selected a programe it would take in water run for few mins then stop,i interupted the programe now it wont do anthing the start light flashes 7 times,as i disconnected the water to pull machine out from cuppboard ,I reconnected it when i pressed the start button you could hear water going in then it stopped and now its flashing 12 times,any ideas or do i have to reset it any help would be great,thanks
    #414117
    nickthebad1
    Re: whirlpool adp 4400
    F7 indicates flow meter has failed. This is the on the left side behind the panel, its the large plastic panel which lets water into the tub. There is a 2 wire connection at the bottom of the panel which connects to a water meter, check to see whether the impeller is turning when water enters the machine. If it is check you have good flow, as the machine relies on the machine filling within a certain time. The unit is easy to replace.
