WHIRLPOOL ADP 4400 DISHWASHER
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries WHIRLPOOL ADP 4400 DISHWASHER
  • #36456
    gilbertandvanstone
    i as hoping someone can help me out with a fault on a customers dishwasher.
    The problem i have when you start any program the machine drains, then fills to the correct level, but then drains again and the start light flashes.
    The base of the machine is dry and i`ve cleaned the water level presure switch located in the sump.
    The drain pump is working ok and its filling ok. I`ve also connected a fly lead directly to the wash motor and that is working also.
    I`m thinking that it is probably the module but if anyone has any ideas, please could you let me know
    Many thanks
    stuart
    #251071
    Re: WHIRLPOOL ADP 4400 DISHWASHER
    Count the pattern of the flashing lamp, then cross check in “Known Error Codes” for the meaning.
    DentedPorsche
    Error codes are in the “Known error codes” sticky.
    Count the flashes from the start light for the error code.
    Brian
