Whirlpool ADP 4500WH Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool ADP 4500WH Dishwasher
  • #12274
    cornwell40
    This machine is starting the programme (ie pumps out) for about three minutes then stops dead. Checked heater, valve, motor all ok. I’m thinking board but not come across this model before. I was convinced before I got there it would be a flood switch tripped but it doesn’t have one 😳
    Any ideas???
    Tony C
    #148811
    Dave_Conway
    Re: Whirlpool ADP 4500WH Dishwasher
    On the earlier “Dolphin” dishwashers this used to be caused by the three lead connector between the PCB and sump (pressure) switch getting wet.
    Looking at the diagram though, I can’t see the usual lower PCB, is it just the main user board in the door on this one Tony ?
    #148812
    cornwell40
    There’s only one board in this model. left hand side of the facia.
    tony C
    #148813
    cornwell40
    Just thought i’d try again with this one.
    You never know????
    Tony C
    #148814
    johnmac11
    Check the NTC Tony, at 20 degrees you should get 58.1k and at 25 degrees it should be 47.1k When you get a problem at the start of the program on the Dolphin range it is usualy down to a leak tripping the flood switch or a NTC problem.
    John
    #148815
    DentedPorsche
    Is the start light flashing an error code? If not then my money goes on a faulty module.
    NTC is the most common start up fault followed by the pressure switch and flow meter connections.
    Brian
    #148816
    cornwell40
    Thanks. I’ll do some checking again!!!
    Whats the price of the board on these, noone has any listings for the model.
    Tony C
    #148817
    Dave_Conway
    Part number 481221848083 at £59.04 ex VAT list Tony 🙂
