Hi all hope someone can help The machine is overfilling this happened after tripping out the “Earth Leakage Trip” last night.Have dried out the machine now want to find out the level detecter.
Vivo
Nope… Regular pulsing is always a PCB fault; this may have been caused by the water leak short circuit. Hose out of circulation pump is always the prime suspect; replacing both pump and pcb is not a cost effective repair.
The Black Circular switch in the sump was bunged up socleaned it but no change.Put it all back together last night, had planned to call out an engineer.This morning it ran a rince cycle with no problems, so tried to run a hot wash.It is sitting at the what seams to be the pump out stage,pulsing at 2 sec. rate.Does this confirm the board dignosis.
Vivo
