Hi guys,
need a bit of help here.
Dishwasher fills up with water and than stops and the start button which also has an in built LED blinks 6 times.
I think it is trying to tell me something dont know what? any ideas
BTW the machine is connected to hot water and has been working fine.
If Flashing 6 times pausing then flashing 6X
Water inlet fault
Check the simple things first IE water supply(is tap turned on),blocked inlet hose filter.Inlet hose kinked
Or could be possible water inlet valve fault ,defective flow meter
