whirlpool adp 7966
  • #18393
    machineman
    hi all have one of these with f4 coming up did a prewash all ok did a 40 degree seemed ok water heated . left m/c customer phoned saying cant switch on to intensive comes up with f4 which i believe is drain problem ,yet the pump works fine .any help would be appreciated.m
    #178848
    gegsy
    Re: whirlpool adp 7966
    Yes it does mean drain problem, however that is only a guide.
    More than likely you have a clogged,dirty or faulty Water Indicator (WI) or at worst a faulty PCB. Im assuming you have checked the waste exit? and its circuitry?
    machineman
    thanks for the reply
    where do i find the wi and is it possible to clean .we have checked water flow on the waste cheers m.
    #178850
    It’s the black grid you can see in the sump – twist fit from underneath.
    machineman
    cheers p
    #178852
    machineman
    cant find a black grid in the sump, did find a pcb the cover came of but i could not get the pcb out is this the w ind and if so how does it come out m
    #178853
    Looks like the new style “OWI” one – it’s at 3 o’clock in the sump.
    machineman
    yeah thats the one took the plug out and the cover but could not get the board out does that get mucky in there.How do you get that out.m
