Whirlpool adp 8693 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool adp 8693 dishwasher
  • #82984
    cornflakes
    unit appears to not heat up
    Runs constantly through programme With cold water.
    No error code showing
    Have stripped down unit, heater shows some resistance when tested for continuity
    Tried to see if voltage present at heater connections, nothing shows when programmed
    Other than E6 and E1 with heater out of circuit.
    Suspect it is the heater did not want to change if something else may be cause.
    Many thanks for any help
    Graham
    Leicestershire
    #421341
    Re: Whirlpool adp 8693 dishwasher
    what resistance of the heater? if its under 100 ohms disconnected then its ok
    cornflakes
    Without returning and stripping down again
    I failed to note resistance
    Assuming the element is ok
    What else might be the problem
    #421343
    broken wires, relay on board inc blown track and solder joints, safety stats if fitted
    deltra
    broken wires at bottom of door ,quite common on these
    #421345
    Grendal
    You can meter the element from the pcb you should get approx 28 ohms. If that is ok it will be the pcb but would need the 85 number to get the correct part no
