Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool ADP 962 Flashing Rinse light during wash cycle
- This topic has 6 replies, 3 voices, and was last updated 18 years, 10 months ago by
just12310.
June 15, 2007 at 7:30 pm #28169
just12310
ParticipantHi All,
We have had the above machine for many years now and it has been faultless. Wait for it… until now.During the initial wash cycle the green rinse status light starts to flash and the dish washer seems to get stuck in this mode.
We have many times cleaned and checked the filters etc during the wash cycle but it makes no differnce. (as per manual )
Eventually it moves on as normal and completes the cycle. Dishes seems to be clean but cycle takes a lot longer.
Any help is greatly appreciated.
Cheers 😀
Just12310
June 15, 2007 at 7:34 pm #217220Penguin45
ParticipantRe: Whirlpool ADP 962 Flashing Rinse light during wash cycle
What is the pattern of the flashing lamp? Ie 1-2-3-4-pause-repeat.
June 15, 2007 at 7:51 pm #217221just12310
Thanks for the quick response.No sequence just continous on off flashing. Even when it passes onto next stage it returnse to the flashing rinse cycle before moving onto the drying cycle.
Hope this helps.
Chees 😀
Just12310
June 15, 2007 at 8:06 pm #217222Penguin45
Aha! The good old NTC problem….. Here’s the last one:
http://www.ukwhitegoods.co.uk/modules.p … ic&t=25242Different badge, same maker. If you put ‘Whirlpool AND ntc’ into Search for this for only, there are lots of examples. ‘Diplomat AND ntc’ works as well.
June 15, 2007 at 8:16 pm #217223just12310
Big THank You
Will investigate and let you know how I get on
Cheers again
Just 😀 😀 😀 😀 😀
June 25, 2007 at 7:18 pm #217224just12310
Hi Penguin,
I ordered the NTC part as advised and fitted. But problem is still there 😥 A bit disapointed as the part cost a fair bit but was simple to fit (*with power off).
Any more tips ? for a fix ?
Thanks 💡
Just 🙂
June 25, 2007 at 8:14 pm #217225gegsy
It may be worth checking that the wires from the NTC to the module are in fact intact by checking the NTC plug contacts (unplugged) for a resistence reading across those terminals 😉
Failing that, you may have one of the rare cases with a module fault showing NTC fault (constant flashing) when its really itself that is faulty 😥
Without us being there, our advice is the best we can give with the experience and info we have 🙂Greg
