Can you help with a problem with my dishwasher. I have a Whirlpool ADP2440WH. When I push the start button the drain pump runs for a few seconds then starts to fill as normal. The water shuts off when it appears to reach the correct level, although couldn’t say this 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}, then after a approx 5-6 seconds the mains light starts flashing 6 times. I’ve read your other threads and checked my flow meter. It spins and if I disconnect the wire from it before switching on the machine the mains light start to flash as soon as the water starts filling. Is there a water pressure sensor that may prevent the machine from operating?
Appreciate any advice you may be able to give. 🙂
