whirlpool adp262wh overfilling
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool adp262wh overfilling
  • #63586
    spanishwhite
    Hi Guys
    Had a call to the above They have had it for 2years but never used it “was 2nd hand and it has never worked”.
    Switched on and it fired up straight away,although it did seem to take along time to fill.Now when it is turned on it is overfilling with water flooding out of the small pipe linked to the overfill switch.
    As i have said before I don’t have a lot to do with d/washers but I would like to sort this one.
    Thanks Steve
    #354212
    Re: whirlpool adp262wh overfilling
    is there any fault codes showing? flashing lights
    look for blockages
    spanishwhite
    Hi Dave,no fault codes or blockages,however when i took the inlet valve off it was connected to what looks like a pressure switch.Took it apart gave it a clean.Washer now seems to be working fine.Fingers crossed.
    Steve
    #354214
    Do you mean the pressure thingy that’s part of the valve construction itself, as in many dw? I haven’t seen one on WHP but then have never looked!
    If it is such a “safety valve” then there’s a 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance you could be in for a recall as these are a pita for sticking intermittently.
    Mike.
    #354215
    spanishwhite
    Thanks Mike,having read your post I spoke to customer and have ordered a new one just in case.(they are paying)
    Steve
    #354216
    spanishwhite
    Just realised,it’s a Beko with a whirlpool badge.
