Whirlpool ADP4400 Fault
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool ADP4400 Fault
  • #67098
    gordo52
    Hi I have a whirlpool ADP4400 dishwasher, last night after just loading it turned on and we never thought anything about until later on checking the start light (green) is flashing, and the water has not pumped away.
    I retried to turn on and nothing, we emptied the clean things, uncoupled everything and drained what water we could outside.
    I checked the inlet and Outlet pipes which were all OK.
    Could it be the pump has packed in, or a switch gone wrong or needs a little more work cleaning and unblocking. I am disabled and can do a fair amount of DIY repairs. left over from when I was at work.
    Advice and help appreciated
    #366283
    Re: Whirlpool ADP4400 Fault
    gordo52 wrote:Could it be the pump has packed in,
    Not draining? Full of water? I think you’re right to suspect the drain pump. It could just be blocked so the next stage might be to unplug the machine and take a closer look around the drain pump.
    #366284
    gordo52
    right, many thanks exactly where does the drain pump live
    #366285
    gordo52 wrote:right, many thanks exactly where does the drain pump live
    Underneath where the drain hose terminates.
    Have you ensured the drain sump inlet to the pump is clear though before going to all that trouble?
    #366286
    gordo52
    Yea it felt clear, not that I can see very well, I will take a look tomorrow when we are visitor free.
    Will post back then
    many thanks appreciate the help
    #366287
    gordo52
    Just an update, I connected everything this morning and still the same I have counted flashing light 4 times
    Kitchen is small so have to take it out in the garage for futher inspection
