Whirlpool ADP4500
  • #67642
    dave-m
    M/c is pulsing, light on and motor action, constantly in half second intervals.
    Has anyone ever successfully got one of these going with the above fault, there’s plenty of threads out there with the same problem but none that show one as having been fixed.
    The fault code book says its an NTC, but I’ve changed a couple before for same problem with no joy and always quoted for a board with no takers to date and here I am again!
    The following are the values of the components, maybe someone can confirm if they are good before I quote for a board again…..
    Heat meggers ok.
    NTC 88k ohms
    Regen solenoid 3k ohms
    Wash pump, askoll, 24 ohms
    Pump 145 ohms
    Solenoid 3.6k ohms
    Cheers
    DOCTORDOOM
    Re: Whirlpool ADP4500
    If this has the board on the front at the bottom, it’s likely to be 1.5uf cap. Farnell is the best place to get one but they have a min. order R46KR415050M1K CAPACITOR, 1.5UF, 275VAC, 27.5MMP ,their part number is 1679322. I bought a pack of 5 and a site folder part number 2058442 which has turned out quite handy. Total price £24.20. Quite easy to solder in new cap. Try searching CW492 and see if it’s the same machine.
