can’t find manual; on starting programme (tried them all!) machine starts to fill (but seems slow); starts pumping out then stops with green light continually flashing??
Re: whirlpool adp4501/05 green light continually flashing
When you say the flash is constant are you sure there are no pauses in the rythm of flashes…the number of flashes before each pause is a fault code. If there’s no pause then that means one flash repeated….
‘F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius ‘
OK; an update.
Dishwasher reset and new cycle sequence tried. Water starts to fill but programme stops and the light starts flashing. There IS a sequence of 11 flashes, pause, 11 flashes etc .
Anyone enlighten me what this error code means please and how to fix??? Thanksjavascript:emoticon(‘:?’)
