Re: Whirlpool ADP4501/5 WH Dishwasher not letting water in
It won’t fill because it already thinks it’s full – probably.
Remove all filters and soak up any remaining water. At the 3 o’clock position in the sump housing, you should see a black plastic grid. This ia the water level sensor and it gets bunged up with grease and food detritus. You may hit lucky and be able to clean out the goo with the sensor in place – an old toothbrush is a good weapon. Hot water can help as well (mind fingers). If it really won’t come clean, the sensor may have to be removed from underneath to allow vigorous cleaning.
Power off if working on the machine.
