I have read previous threads but can’t find one for 15 flashes. Can someone pls help. Initially the soap drawer was not opening. I removed the outer door cover to view the soap draw solenoid etc. I manually operated the levers and lifted the plunger to release rinse aid. All ok. I started the machine on a wash to observe the solenoid operation of the soap draw. It was soon obvious that a large amount of foam was forming in the machine, possible from excessive rinse aid. The wash cycle completed but the soap draw solenoid did not active. I powered off the machine and went to try again. This is when I got the 15 flashes on the green start light.(have seen and used previous threads to determine faults from this light). The machine automatically drains and the light sequence continues. It is possible to press and hold the start button to cancel the drain and light sequence, and continue with the program selected. However as soon as the power is turned off the problem is back! Put pumps and and heater on this machine previously to successfully fix faults. Latest pump still in warranty so don’t want to get rid of machine if it can be helped. Many thanks in advance for any help.
