Can anybody help with this please at a Whirlpool dishwasher drains then fills then stops filling and flashes 6 times, error code points inlet valve, that is okay i’m now thinking of the flow meter or maybe the wash motor as it fills and just sits with no wash action cheers in advance JJ.
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less
than 10 impulses in 10 secs.) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
