whirlpool ADP4602L – not draining water
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool ADP4602L – not draining water
  • #43655
    markcroft
    my whirlpool dishwasher ADP4602L (door plate numbers 8511 505 15840 38 0412 006388) has stopped working.
    When switched on the start light flashes 4 times. Can force it too start by holding the start button but will stop about 4 minutes into wash cycle , it will have a lot of water in the bottom as well about 3″ not enough lucky to splash out when the door is opened.
    Seems to be related to the pump from previous posts on the forum about whirlpool?
    What is the part number for pump?
    Where a good place to order replacement?
    Is it quite straight forward to replace the pump? I guess just time consuming and good screwdriver.
    MARK
    #278021
    Simon46
    Re: whirlpool ADP4602L – not draining water
    Power off drain pump off remove object. If jammed it will just hum.
    S.
    #278022
    markcroft
    there was something blocking the fan inside the drain pump and the pump spins around as normal (its quite noisy not as much as before).
    The start light still flashing 4 times.
    What else could the problem be please?
    #278023
    mallyfam
    I have to admit complete ignorance of all things white goods, but if you look at my recent cry for help (“Capel DI414”) from last week, this may help. It worked a treat for me and saved me a fortune.
    Good luck
    WM
