whirlpool adp5966 D/washer flashing start button
Home Forums Public Support Forums Help And Support Dishwasher Help Forum whirlpool adp5966 D/washer flashing start button
  • #14494
    tazzman916
    My d/washer has stopped running its program, the start button starts to flash when you hold it in it just ends the program. Then you get the same thing happen again, no error code comes up?
    Can anyone help regards Ant 😥
    #159653
    Re: whirlpool adp5966 D/washer flashing start button
    NTC failure is the most likely culprit with no start problems. This is the temperature sensor. Can be a tricky fault to diagnose without test equipment. Professional help is probably your best course of action.
    Click the link below for a UKW engineer in your area. Power off if you wish to investigate further.
