Whirlpool adp5966 dishwaher F3 error
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool adp5966 dishwaher F3 error
  • #5318
    Anyone shed some light as to what might cause error code F3 on a Whirpool ADP5966 dishwasher>
    Ta
    #110512
    Re: Whirlpool adp5966 dishwaher F3 error
    F3………1) Heats the water too slowly.
    2) No heat
    usually takes 29 minutes to fault to F3
    I think this dishwasher is the optical sensor one which means any of these can be faulty.
    Sensor…4812 271 28459 Could just want cleaning(the lens surface gets grubby)
    heater(tube type) 4812 259 28684 Check resistance and insulation
    base control card…….481221478704 .. inspect for edge connections and blown tracs on the board(indicating failure elsewhere in the dishwaser)
    even if you are extremely confident in your abilities I would recommend you get an experienced engineer to this, it could well save you money because wont need all three parts.
    ted
    #110513
    DentedPorsche
    Whirlpool result for error code F3.
    F3 indicates a Heating System Defect.
    Heater or relay on control board defect.
    Also check cabling.
    These machines are notorious for bad connections.
    The control board can also suffer from corrupt software. The eprom can be reprogrammed with the right equipment.
    #110514
    The eprom on these appliances is not reprogrammed by the use of what whirlpool call a SAM module. All this does is to reset the error code, and these sam modules have been a complete flop.
    A very expensive piece of rubbish that a good engineer does not need.
    In fact on two occasions the base module has packed in altogether when the fault code has been reset, and guess what Whirlpool Technical have no explanation as to why, the fault at the time was auto syphoning due to poor installation, reseting the module ###### it.
    ted.
